Can i set it up like this?
380 Views 7 Replies 3 Participants Last post by  5291Crash
ADSL into modem
Modem to main comp (to control MLPPP single link connection)
Main comp (2nd nic) to router
router to other comps wirelessly
I am with Teksavvy on mlppp so i don't get throttled by bell, and my router can not do a mlppp connection i need to share the net with another comp upstairs
will this work if i set the connection to share across my internal network?
Networking is something i am still learning slowly
Thoughts?
1 - 8 of 8 Posts
Simple answer. Yes you can use your PC as a bridge between the router and modem.
Yes, it's possible.
How do i go about setting it up like that aside from the wiring?
Both PC's are XP
Router is a D-link wbr-2130
Since you're dialing with the main computer you'll have to do with ICS - bridging the connections will not work.
Here's how to use ICS:
http://support.microsoft.com/kb/306126
OK thanks
how do i set the router to forward all internet connection requests to the dialing computer?
Originally Posted by 5291Crash
OK thanks
By plugging it into the WAN port. Or by going into static routing and adding that as the default gateway with an IP destination of 0.0.0.0
thanks
1 - 8 of 8 Posts
