That shouldn't matter with twitch, though, because they take your stream and distribute it to the viewers. The viewers are not actually connecting to you directly.
how do I do that and is there ways I can increase my upload speed?
stream your game (it's upload anyway) and get a laptop and watch your stream (download)
You have to pay your ISP more money to increase your upload speed.
I used to use Wirecast and Xsplit, I dont think this was out back then, but since this is a free option, i'm with IAmDay on this oneOriginally Posted by IAmDay
I would use OSB. Look it up and tweak the settings to best fit you.
http://obsproject.com/
That's odd. I'm pretty sure I have watched 720p off youtube on a 1Mb connection without issues
Well yeah but like someone mentioned with twitch you are only uploading to the servers and they mirror your stream out to the viewers. But you might be right as I don't know what type of compression is used with twitch.
OBS is great and you can choose everything. Mine is customized to my liking and I love it. Not to mention FREEOriginally Posted by Tatakai All
Like others have said, you system is up to par for streaming but your connection is a bit low. You mentioned streaming at low resolutions like 420p or 580p, I think you'll be fine with that but your stream will be low quality with big pixels. What are you planning on streaming?
EDIT: I stream on twitch via xsplit but thanks to "IAMDAY" I'll be checking the link he provided.![]()
