1 - 7 of 7 Posts
okay so i fineally got my 120 gig drive back and i have set as fat 32 so i can use it with my box and other windows systems.. i backed up 40 gig which was ntfs i am currently using a 10 gig drive for my system.. what i would like to do is swap the 10 for the 40 gig.. more space and faster drive what i dont want to do is reinstall my distro.. i have tons of stuff i configured myself and dont really wanna have to try and figure out how to do it again.. so is this possible.. to do.. can i mirror my drive onto the 40 swap it out and be good to go.. if so how would i go about doing this
Most hard drive manufacturers provide tools that will accomplish just this. If the HDD did not come with a CD, you can usually download the software from the manufacturer's website. Once you boot from the CD, selected Setup a New Drive. It will ask you how you want to partition it, if at all, and if you want to add it as a storage drive or a new boot drive. If you select it as a new boot drive, it'll mirror the contents of the current boot drive. I've done this several times, always with good success.
It should still work.. it is just transferring data.
EDIT: It might give a 10gb partition on the new drive, and leave 30 unallocated.
I would think so since Taeric said it boots off the CD.
Discussion Starter #6
so no one knows for sure.. i mean linux is picky about its hardware setups..
Discussion Starter #7
well i guess it is going to be that easy.. and after searching around i found the perfect solution for my problems i think i wont know till everything is done.. but linux has a program called PARTIMAGE which makes images of your partitions use of this in combo with the ubuntu live cd and a usbdrive should make things pretty smooth and i dont have to worrie about getting stuck with a 10 gig spot on a 40 gig drive and having to add the free space back to it.. i just have to make sure i have enough space on each partition and it will fill it all back up and leave the left overs to play with
1 - 7 of 7 Posts
