Can i unlock this 6800gs?
1677 Views 19 Replies 9 Participants Last post by  Namrac
hello,
is there anyway you guys know of, of unlocking the full potential of this card?:
http://www.newegg.com/Product/Produc...82E16814130265
because before i buy it tommorrow i want to know if i can unlock it to 16 pipes?
thanks everyone!
1 - 20 of 20 Posts
its different for every card, if people knew "for sure "the ycould buy a specif card and unlock it, then nvidia or ati would have sold them as the full version card in this case its a 6800GS, if it was able to unlock easily they would havesolt it as a 6800u. So it just depends on each card, so there is a chance it will unlock and a chance it wont.
O i see, i was just wondering because it said on one of the reviews for another card that they could unlock it to 16 pipelines and my tech freind told me that this was the best 6800gs i was going to get for this price, does anyone disagree?
again..very much appreciated
· Premium Member
Originally Posted by Lucid
there is never a 100% gurantee
I've heard that, but everyone that I have heard of that has flashed to a 6800GT bios has said they had complete success...
The AGP 6800GS has great potential, even without the unlock. with a good cooler, you could probably get it to about 540/1.25
your not going to get any unlock out of that card on the PCI-E version, this is due to the GPU core, and I have tried myself without luck, the 6800 does unlock in AGP version I'm not sure about the 6800GS AGP
· Banned
Thank you lol.
Ok.
The 6800GS PCI-E is built around a totally revised core. It only has 12 pipelines and 5 vertex, there physically isnt anything left on it. On the up side, its also clocked enough to compensate for the lack of pipes and overclock usually over 500/1100.
The 6800GS AGP is built around the old 6800GT core, thus it has 16/6, but is sold at 12/5. Most of the time 16/6 is unlockable without trouble though.
· Banned
Originally Posted by Some_Idiot2
PCI-E GS's DO NOT UNLOCK, ONLY AGP GS'S, AGP ONES WILL unlock 99.9999999999999999% of the time with a 1.4V custom BIOS.
Well that was rather forceful lol
· Banned
Originally Posted by suthernkid
change of plan i ordered the pci-express 6800gs from evga can unlock that one anybody think?
No. You cant unlock ANY PCI-E 6800GS. It doesnt even have the same core as the 6800GT and the GPU itself is smaller because it doesnt have any thing to unlock. Just overclock it past 500/1100 and youll be happy.
· Premium Member
ok then lol but thank you anyways..but i should be able to do that woud anyone reccomend getting a 3rd party cooler or sticking with stock?
Zalman VF-700cu is the best..In my opinion.. They are on newegg for fairly cheap.. Though, unless your planing on doing some serious OCing, I would stick with stock...
· Premium Member
Depends on what version of the card you ordered. There is a regular version, and a higher clocked, copper heatsinked version. If you got the latter, there's no real need to get a custom heat sink, it's good enough already.
1 - 20 of 20 Posts
