Can i up the voltage moar? (pics)
311 Views 3 Replies 3 Participants Last post by  elito
My question is this, even though i have the voltage rating at 1.38v within the BIOS, can i up the voltage more? I need to do this because although everything is stable, my sound is skipping/crackling as it does with overclocking, i have found that with my cpu i have to have the voltage to speed ratio just right for perfect sound. Here are some screenies...
Thanks
1 - 4 of 4 Posts
Im not sure about amd, but intel 65nm can go up to 1.5V
Bump? ( i have it @ 2.9 now btw)
yes you can definitely increase the volt. you can use upto 1.55 extreme max'ed out. id just make sure to stress test your current oc settings so that youre stable.
1 - 4 of 4 Posts
