Technically you could but you would probably be better off just using rivatuner. Most GPU fans use a 3 or 4 pin mobo connector that connects to the card, so you could unplug it from the card and run it through a fan controller I suppose. Just using rivatuner to control the fan speed is about 100x easier though.
