With 2x 8ohm speakers in parallel you are going to get 4ohm impedance. Worst case scenario is the overheating of the receiver when the load impedance is too small. Just use one speaker instead of two.My speakers are 8 ohms
And also the reciever has 8 ohms out for channel
So I was worries if I combine two 8 ohms and use the reciever out put will it cause any problem for reciever?
Of course if the receiver has support for 4ohm speakers then it's fine to go parallel.
