1 - 3 of 3 Posts
Im buying a 6800GT by Asus 128 mb on newegg.com for $339. It doesnt come with a computer power cable that goes from the video card into a free wire on the power supply. Can i do a trick and take the cable from the power supply and try to make it fit into the card without any extra cables needed or get 1 with the extra power cable?
Thanks a lot
You shouldn't need one. My friends used a standard molex connector (the big 4 pin one).
Which card are you getting? Toss up a link.
1 - 3 of 3 Posts
