1 - 3 of 3 Posts
I have Gigabyte GA-7VAX, with a 2000+ cpu on it, although the onboard system bus is only at 100mhz as i have problems when running it at 133mhz.
Here is my memory from cpu-z:
DRAM TypeDDR-SDRAM
DRAM Size768 MBytes
DRAM Frequency140.3 MHz
FSB: DRAMFSB + 33 MHz
DRAM Interleave4-way
CAS# Latency2.5 clocks
RAS# to CAS#3 clocks
RAS# Precharge3 clocks
Cycle Time (TRAS)6 clocks
# of memory modules3
Module 0DDR-SDRAM PC2100 - 256 MBytes
Module 1Hyundai Electronics DDR-SDRAM PC2100 - 256 MBytes
Module 2Hyundai Electronics DDR-SDRAM PC2100 - 256 MBytes
Can you tell me if i can run the following memory on this board if i get rid of the 3 256mb dimms, or even leave them in with the 1gb dimm?
Kingston 1GB DDR PC2700 333MHz Non-ecc CL2.5
http://www.ebuyer.com/customer/produ...duct_uid=55910
Cheers.
I couple of things from my manual.
3 184-pin DDR sockets
Supports DDR DRAM PC1600/PC2100/PC2700/PC3200<Note 2>
Supports up to 3.0GB DDR (Max)
Supports only 2.5V DDR DIMM
<Note 1> FSB333 MHz only support DDR333 DIMM module.
<Note 2> PC3200 only support by Micro, Samsung, Apacer DDR module as we verified, more detail
pls refer to P.103
1 - 3 of 3 Posts
