Can I use with this mobo?
459 Views 5 Replies 4 Participants Last post by  Ladiesman101
Can I use these on my GIGABYTE GA-EP45T-UD3LR mobo?
http://www.newegg.com/Product/Produc...82E16820231303
1 - 6 of 6 Posts
Are you sure... they say they are designed specifically for P55 boards
DDR3 is DDR3. You could buy a tri-channel kit and only use two of them if you wanted even though it says its designed for I7s
When it says they're designed specifically for a certain type of board, it is typically the voltage tolerances that are set a particular way. Regardless, like NZi said, DDR3 is DDR3.
yup
its a great mobo man
u will enjoy it pretty much
great OCing board.
1 - 6 of 6 Posts
