Can intel HD4500 do smooth unecrypted 1080p?
12493 Views 10 Replies 6 Participants Last post by  mothergoose729
I am going to build a mini ITX HTPC for my living room. My plan is to back up my DVD's and blu ray on my PC and broadcast it wireless via home network to my HTPC. I was thinking about getting this motherboard, because it is cheap, and has all the features I really need:
http://www.newegg.com/Product/Produc...82E16813121381
I plan on teaming it up with 2gb of DDR2 667, and what looks to be a E5300 (which I will likely underclock to 2.0-2.4ghz). Will this combination be enough? I have read some reviews, and it seems the latest bios does a great job of offloading onto the graphics, but I want to be sure.
Also, completely unrelated, but what is the maximum resolution I can display out (I will be getting an S video out adapter)? I am going to use it in conjunction with a Sony WEGA 50 inch television.
And hell, while I am asking, what are some of the better (but affordable) wireless PC remotes? Something I can use in place of a mouse would be pretty great too.
Answers to any of these question would be wonderful thanks
1 - 11 of 11 Posts
OK, Deep breath. You cannot stream 1080p video very well. It's a lot of headaches and you will need an "N" router and receiver. G or slower will simply not work. Even N will have trouble with non compressed 1080p. Best to go wired. Also, if at all possible, use HDMI to connect to the computer. S-video has a max of 480P, component has a max of 1080i and HDMI has 1080p. Analog signal via VGA will also not be as sharp. Here is the remote I bought. I just used the IR receiver, stored the remote, and used my Logitech Harmony to control media center. If you don't have a Logitech Harmony, what are you waiting for? What is this? The fifties? You need one. If I were you, I'd go with a G45 platform with onboard HDMI. You won't need a video card and it will play an video size you throw at it. Here is a mini ITX g45 platform. These things were meant for HTPCs. I can't wait till I can throw my G45 from my main rig to my HTPC once I upgrade to an X58 chipset.
Edit: Forgot to answer your question. See below from Wiki. Short answer, No.
The GMA X4500 and the GMA X4500HD for desktop[12] were launched in June 2008.[13] The GMA X4500 is used in the G43 chipset[14] and the GMA X4500HD is used in the G45 chipset[12]. The GMA X4500 is also used in the G41 chipset,[15] which was released in September 2008.[16]
The difference between the GMA X4500 and the GMA X4500HD is that the GMA X4500HD is capable of "full 1080p high-definition video playback, including Blu-ray disc movies",[12] the GMA X4500 however does not have that capability.[13] The G43 and the G45 chipsets are manufactured with 65 nm technology.[19]
According to a number of review sites, even the G45 chipset is borderline, and will stutter in scenes with lots of action. You're probably better off getting a cheaper mobo & using a stand-alone Radeon HD 3450 / 4350 / 4550. Or, if you're intent on going mini ITX, either GeForce 9300 or ATI/AMD 780G/785G integrated.
Well I wanted to try and save a little bit of money going with intel graphics, but it looks like I am going to have to go for a either the intel zotac board with a geforce 9300, or a jetway 780g board. Thanks a lot for you guys comments.
correction component also does 1080p just in analog video, HDMI is digital which gives a better picture technically. I personally don't see a difference between HDMI & component in 1080p
http://en.wikipedia.org/wiki/Component_video
Component video is capable of carrying signals such as 480i, 480p, 576i, 576p, 720p, 1080i and 1080p[1], and new high definition TVs support the use of component video up to their native resolution.
My G45 plays 1080p WMV or .MOV files perfectly on integrated graphics, but these are compressed files that require a lot less HP than blu-ray. assuming you will be ripping blu-rays into MKV files, you should be ok with a G45, though I'd go with a mATX instead of ITX so you can upgrade to a video card later on if needed.
My xbox360 will do menus at 1080p via component but it won't deliver 1080p when playing HD-DVD's. Using componet on my video card also only let's me output 1080i to my TV. I thought that analog 1080p was capped due to DCHP concerns (no encrypted HD video @ 1080p via analog). I guess you learn something new every day.
If you're going to be serving up high profile H.264 video @ 1080p, I'd say the G45 IGP is going to be iffy. You're far better off with an AMD/ATI HD3200/HD4200 or Intel/Nvidia 9300/9400 platform if you want good HD video. If you also want low power consumption, I would definitely go with AMD since they have a nice variety of low-wattage chips.
Well the TV I have is kind of old, and the only hook up it has is S video out and component. It is good to know that I can get a 1080p analog signal this way.
Being such an old TV.... is it 1080p?
Actually yes. According to the manual it is.
1 - 11 of 11 Posts
