1 - 10 of 10 Posts
So i am thinking about swapping out my 4870 for a 4850X2 and i am wondering if my PSU could do it?
Not new to Overclock.net
I'm pretty confident that it can do it, although I would like some confirmation.
I'm not sure... Just like TwoCables, I am pretty sure that it would do the job, but lack any kind of confirmation. Sapphires website says:
" 650 Watt or greater power supply with one 2x3-pin PCIeR power connector and one 2x4-pin PCIeR power connector is required (1K Watt with two 2x3-pin and two 2x4-pin connectors for ATI CrossFireX™ technology in dual mode)"
But being that Corsair makes some great PSUs who performs a notch over the rest, I'm not sure.
EDIT: Just realized you said 4850x2... I thought it said 4870x2 lol. Yeah it should do it just fine
It can handle it, but it leaves you less headroom than I'd like. You're looking at around 400W total consumption. With a figure like that I'd prefer a 650W PSU.
Originally Posted by meticadpa View Post
http://www.****************/reviews....raphics_card/4
That's with an i7 rig. Your power supply can do 41A/492W on the 12V rail, so you should be fine.
For some reason I can't link to the review site...
I think I know which site that is then. But I can't remember the exact site name.
However, there's a very good reason (as explained very well by admin) as to why it's censored.
As others have said, without a doubt you can. I'm not running a 4850x2 but I am running 2x4850s on my 500w PSU without a hiccup.
1 - 10 of 10 Posts
