Not unless you increase volts too much or temp gets too high.
Edit: You need more volts for 850MHz core; your card was not damaged in any way.
It's like setting your CPU to 6GHz on stock volts, it shuts off due to lack of voltage.
Originally Posted by XFreeRollerX ![]() Now if I start upping clocks again on my card(under watercooling) is there a point where I start risking problems again? cards load at 46*C |
