1 - 3 of 3 Posts
So I really want to get my rig watercooled so I can get some nice temps for the upcoming summer. I want to go for something very clean looking, and having the res and pump mounted separately just doesn't do it for me. lol. So do you guys think that something like this keep up with the performance of a regular setup?
http://www.performance-pcs.com/catal...7fdd84d4b95592
I know this one specifically seems cheap but if so can you point to a good one.
That's interesting. If you're concerned about the build quality, you could also consider a reservoir pump top for pumps like the Swiftech MCP355, like this one.
I saw a review Here:
http://www.pureoverclock.com/article889.html
The performance is not that far behind the 655 pump. I am getting the same part. It saves a bit of money, and space as well. I think you can also get an empty Reservoir/Pump where u buy the pump seperately, at which point you can either purcahse the 655 or the 355, but I am sticking with the X2o 750 combo :)
1 - 3 of 3 Posts
