okay, im having problems with my computer i just build yesterday that i got from newegg (below). Im having problems with my onboard audio device (newest ASUS BIOS), first I had the nvidia audio chipset driver on there. Then that didnt work so i put the newest realtek audio driver from asus, and that didnt work. and to top it off every time I try and start BF2 (newest update) it crashes. This happends every time, ive even reinstalled windows 3 times, also the computer has crashed at least 10-15 times in the past 20 hours or so.....so if anyone can help me, or tell me what i should do, thanks.
Thermaltake XASER, Armor Series VA8000BWS Black Aluminum/Steel ATX Full Tower Computer Case
ASUS A8N32-SLI Deluxe Socket 939 NVIDIA nForce SPP 100 ATX AMD Motherboard
AMD Athlon 64 3500+ Venice (Model #: ADA3500BPBOX)
THERMALRIGHT XP-90C Heat sink with Vantec tornado case fan
Antec NeoPower NeoHE 550 ATX12V 550W Power Supply
G.SKILL Extreme Series 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 500 (PC 4000) Dual Channel
Albatron 7800GTX Geforce 7800GTX 256MB 256-bit GDDR3 VIVO PCI Express x16 Video Card Bundled with Call of Duty 2
Western Digital Raptor WD740GD 74GB 10,000 RPM 8MB Cache Serial ATA150 Hard Drive (main drive)
SONY White IDE DVD Burner With Black Front Panel Model DRU810A
