They will work. Just go into your mobo BIOS and look for something like "SATA Mode" and set it to RAID. That will invoke the RAID BIOS to run during boot. When the RAID BIOS screen comes up during boot (you should be able to easily tell it's for the RAID) press whatever key it says to enter setup. Once there, setup the array (pretty straightforward). Good luck
please DO remember to backup your data though! as any drives you put into the array will be wiped clean!
You dont have to use the same size drives, but it's recommended that you use the same size identical drives for easiest use for doing a RAID0.
If you search the forums here there's quite a bit of info on how to setup RAID.
You need to setup your RAID first by entering the RAID bios and after you're done creating it, you'll have to install windows as if you'd normally install it.
You just have to load the raid driver during windows installation.
Just a heads up, if you RAID0 all of them, your resulting disk will be 160x3=480GB instead of 250+200+160=610GB so you are losing a total of 130GB usable space by using RAID0.
Your raid config will take the size/ doubled of the lowest GB drive. So you will only have a 400GB raid drive when you raid both the 200 and the 250. Not hard to setup really, just head to bios and do a clean slate with the install. Best of luck to ya!
I recommend looking in the manual for your motherboard to see how to setup a RAID array. From my experience every motherboard is different with its onboard setup.
You probably need to install the Intel RAID drivers now (get them off your mobo cd or from Intel's website)
If you dont have the mobo cd, use a flash drive to copy the driver then when you install Vista there should be a button that says "Load Drivers" and you can select them off of the flash drive (or the mobo cd if you have it)
EDIT LOL i didnt see you had an AMD board. Replace INTEL with WHATEVER YOUR BOARD MANUFACTURER USES
If all three drives are on the same controller it may not see the third one as it is not part of an array. As for why it doesn't see the RAID 0 set, Vista may not have the driver for your controller in which case you will need to put it on a floppy and enter it in manually. I know Vista has Intel's drivers but I don't know what controller the AMD boards use.
Also, you should be able to get a software RAID manager of some kind for your chipset... if it has one, it should have come with the driver CD/floppy or can be found on the web
Originally Posted by t_russell
It should be transparent but you can run HDTach and get your performance numbers. Use xp compatibility mode for this app.
Another option is HD Tune which will show you both read and write speeds (if you get Pro, which has a 15 day trial I think).
Overclock.net
