1 - 8 of 8 Posts
I'm mainly wanting to cut some holes for two fans in the top of my A05, but what a high quality dremel just for whatever future use I may come up with. Any and all links are appreciated, but something reputable is preferable.
This one should do the job.
[ame="[URL=http://www.amazon.com/gp/redirect.html?ie=UTF8&linkCode=ur2&camp=1789&creative=9325&tag=overclockdotnet-20&location=http%3A%2F%2Fwww.amazon.com%2FDremel-300-1-24-Variable-Speed-Rotary%2Fdp%2FB002BAHFBE%2Fref%3Dsr_1_1%3Fie%3DUTF8%26qid%3D1311003789%26sr%3D8-1]http://www.amazon.com/Dremel-300-1-24-Variable-Speed-Rotary/dp/B002BAHFBE/ref=sr_1_1?ie=UTF8&qid=1311003789&sr=8-1"]http://www.amazon.com/Dremel-300-1-24-Variable-Speed-Rotary/dp/B002BAHFBE/ref=sr_1_1?ie=UTF8&qid=1311003789&sr=8-1[/ame[/URL]]
Get the dremel 4000 with the flexi attachment, it cost a bit more, but I haven't regretted it one bit:
http://www.amazon.com/Dremel-4000-2-30-120-Volt-Variable/dp/B002L3RUVG/ref=sr_1_1?s=hi&ie=UTF8&qid=1311068102&sr=1-1]Amazon.com: Dremel 4000-2/30 120-Volt Variable Speed Rotary Tool Kit: Home Improvement[/URL]
The flexi hose is in the frequently bought section, the big advantage of that is it allows you to use a much smaller tool and you can get much closer to what you want to cut so you don't have to cut things on an angle.
1 - 8 of 8 Posts
