1 - 5 of 5 Posts
The only way damage would occur is if there was a spike or surge in power before it went out and your surge protectors failed to protect. As far as the power just getting cut off I don't think it would hurt anything. It would be like just unplugging it from the wall and the pc just loses all power.
Originally Posted by calavera View Post
How can I tell if a surge of power occurs before the outage?
If the computer catches on fire! :D
No, if your surge protector does its job, it should fry that instead, or blow a fuse, or flip the switch. Whichever it does, I've never actually had that happen.
Some higher-end surge protectors offer a warranty for everything plugged in in case it fails to protect your stuff from a surge.
1 - 5 of 5 Posts
