1 - 2 of 2 Posts
Hello.I got a Sirtec 550W Eco II psu.I decided to sleeve my cables but i can't get those bastards out.I tried pushing the tiny wings with paper clips but i can't even hear the click.Is the psu built diferently or am i missing something?
If you are having trouble using paper clips with this method it's probably a question of getting the thickness right. You need to get it just so that both blades can reach the bottom of the nozzle together. Also, try pushing the pin fully into the housing before trying to extract it to prevent the lugs digging into the plastic against you.
1 - 2 of 2 Posts
