1 - 2 of 2 Posts
Just as thread says. Anandtech says the overclockability is better on F7 vs F6, but F7 is only listed for the DS3, not the S3.
As I said in the other thread,<br />
<br />
Why don't use just use the <a href="http://www.gigabyte-usa.com/Support/Motherboard/BIOS_Model.aspx?ClassValue=Motherboard&ProductID=2321&ProductName=GA-965P-S3" target="_blank">F6 BIOS for GA-965P-<b>S3</b></a>?<br />
That BIOS update adds the same "Support Intel Core 2 Extreme Quad-Core CPU (Kentsfield)" as the F7 does for the DS3.
1 - 2 of 2 Posts
