Can the HAF 932 fit a 360mm rad?
1299 Views 7 Replies 6 Participants Last post by  ounderfla69
Well I got some money finally
and I'm putting a water loop in my case, but I'm not sure if it can fit a 360mm rad. Any help is appreciated.
1 - 8 of 8 Posts
Yep. You won't be able to put much in the top 1-3 drive bays (depending on thickness), however. Drives won't fit, but things like fan controllers will.
vie got a 480 on top of mine but i know a 360 will fit inside on the top.
A 360 radiator will fit internally at the top of the case no problem, only thing is that you will not be able to use the top drive bay. I got a 360 rad at the top of my case which is basically a redesigned and refined HAF 932
Yup... 360 on top easy. You can use a SHORT device (card reader, or fan controller) in the slots partially blocked, but, that's about it.
Alright thanks guys +rep
Oh, I forgot to mention.. it may *look* like it won't let the air out from the 3rd fan, but it will... there's vents in the plastic housing =)
Enjoy the new rad!
The swiftechs and the GTX and I believe the fesser will too, but the PA series have a different hole spacing and will require some mods.
1 - 8 of 8 Posts
