I recently built a computer for the purpose of playing SWTOR, and I intend to upgrade my RAM and possibly CPU soon. My question relates to these upcoming decisions.
Relevant current components:
ASUS Sabertooth 990FX R2.0
Phenom II X4 965 BE C3
2x8GB DDR3-1333 Kingston ValueRAM (CL:9)
I bought the 1333 RAM because I didn't realize I could underclock memory (herp derp) and I thought stability might be an issue. Upon correcting both misconceptions, I realized that I should have bought DDR3-1600 with tight timings. So, I asked my wife if I could spend $100 on more RAM. She said I could. I then learned on these forums that upgrading to slightly faster RAM with the same timings as my current memory will have a negligible impact on my gaming performance.
However, as many of you can probably understand, when your woman tells you to go buy more computer hardware, you go buy more computer hardware. 'Nuff said.
So I got to thinking, I could buy some DDR3-1600 with tight timings, but if I want to upgrade my CPU in the not-so-distant future to, say, an FX-8350, I might want some DDR3-1866, which would be another $100 on top of the DDR3-1600.
Unless, I just bought the DDR3-1866 now (was considering this) and then underclocked it to suit my Phenom II.
I have also read here that Phenom IIs really fly when they've got some DDR3-1333 with insanely tight timings. However, I can't find any kits of 2x8GB of high performance DDR3-1333 on Newegg, and with the way browsers have been eating more and more memory in recent years, I'd really rather have 16 GB total with just two DIMMs.
So my question is, if I bought the G.Skill kit I linked two paragraphs ago, do you think I can really tighten up its timings if I underclock it to 1333? I mean, does the fact that it's rated for 1866 give me a bit of flexibility there? I don't expect to be able to get its CL down to 5 but it would be cool if I could get it down to 7 or 8.
Any thoughts are appreciated.
Thanks much!
Thanks much!
