1 - 4 of 4 Posts
HI all
1) Can you fit two K-KIT 360 HFX in the bottom of the case without modifications to case, please notice i use an extended ATX motherboard (( RAMPAGE IV EXTREME )))
If you can answer yes to the above question ( do i need to order reverse ATX Layout ??? )
I really want the motherboard to fit normal in the case
( K-KIT 360 HFX Dimensions (LxWxH): 400x130x64mm )
Extended ATX Form Factor ( 30.5 cm x 27.2 cm )
http://www.ekwb.com/shop/kits-cases/kits/ek-kit-h3o-360-hfx.html ( K-KIT 360 HFX ) Dimensions (LxWxH): 400x130x64mm )
http://www.asus.com/Motherboards/RAMPAGE_IV_EXTREME/ ( RAMPAGE IV EXTREME ) Extended ATX Form Factor ( 30.5 cm x 27.2 cm )
Hope to here from you soon :)
/BR
Nikolas Didonis
Enthusiast Cases
Probably not on the bottom of the MB side of the M10 (top & bottom of the PSU side would be fine). I'm sure I understand why you would use two kits though because at a minimum, you would have redundant CPU blocks. The RIVE will fit fine. the 305mm dimension is standard for ATX.
Hi
Thank you for your quick reply :)
Bear with me, but I only I want to install one KIT of EK-KIT 360 HFX but with an extra waterblock
So in total 2 x EK360 HFX one in top and one in the bottom of the PSU side of the M10 case.
do you think it will fit in the case without modifications to case top or bottom
http://www.ekwb.com/shop/radiators-fans-accessories/radiators/120mm-series/ek-coolstream-xtx-series/ek-coolstream-rad-xtx-360.html
((( EK360 HFX )))
http://www.ekwb.com/shop/kits-cases/kits/ek-kit-h3o-360-hfx.html ((( EK-KIT 360 HFX ))))
Hope for your replay
1 - 4 of 4 Posts
