Hello, fellows, how does it look?
Max load voltage is 1.128v @ 4.3GHz, overclocked using the Turbo multipliers.
Here's the Prime95 result. I used the Blend test recommend in the ASRock OC thread.
8 Hours:
HWiNFO64 readings:
I've also play some hours of BF3, it seems stable. On that game it stays at around 60c.
There are some things that make me worry a bit.
The 2nd core seems to always be 4c hotter than the other cores. Is this why it did fewer (170 less) tests than the other cores?
Also, are the number of tests ok for 4.3GHz?
Also, I've seen in different places that people need more voltage than I did here for 4.3GHz. How bad it is to run your CPU at low voltages, can something go wrong?
Any tips are welcomed.
8 Hours:
HWiNFO64 readings:
