Can you track EUE's?(Yes you can)
387 Views 9 Replies 6 Participants Last post by  cuy50
Is there a way to track them, beside the [email protected] logs?
Does Stanford keep a database of a users EUE count?
Get it here.
1 - 10 of 10 Posts
still learning what an EUE is....
will check thread in an hour.
will read again.
will read again.
Early Unit End
Usually means some kind of system stability problem.
I have wanted to know a way of doing this for a long time. To my knowledge there isn't one.
ok so when EUE's happen...your system pauses for 24 hours right?
means I haven't seen one yet......thank god....it would definitely drop my points a lot in the gpu comp
yeah I just try and avoid them, but if I just changed the clocks on something I monitor the log...
yes if you don't close the client and reopen it
Not all WU than end early cause the 24 hour pause.
The "Unstable Machine" error just stops the current WU, sends in what you have done and then DL a new one, the EUE does do the pause for 24 hours.
Not real sure what the diference is in them though and what causes which to happen.
This is a nice program! Thanks.
Edit: I have an 8% EUE rate. Not bad.
1 - 10 of 10 Posts
