Can your WC rig handle "silent mode"
1218 Views 27 Replies 24 Participants Last post by  21276
When I am browsing or working with office apps and desiring some peace and quiet I cut the OC and volts back to stock and shut dowm all fans (except GPU).
Temps stay nice (in mid to high 30's c ,mid 40's c for GPU) and I really like the quiet. Can most do this on their WC rigs?
1 - 20 of 28 Posts
Not on my i7. The loop gets hotter and hotter. Eventually I suspect the pump would fail due to the boiling water inside. My idle also shoots up to ~65 (thats where I turned the fans on)
My loop is always in "quiet mode". I have Gentle Typhoon's on an XSPC 480 for just my CPU, and I hear rushing water over anything else. Quiet works best for me!
Even when you turn the volts and speed back to stock?
As long as i dont play games my rig can stay going with all fans on low. its dead quite when i do that. i mainly do it when i watch movies
The pump is SILENT. I mean, dead silent.
My 6 70CFM fans... aren't. Undervolting them to 6v, makes the HDD noise equally audible. GPU temps stay in 39ºC and CPU temps in 30ºC idle.
On [email protected], well, the system can handle it (GPU 42-43, CPU 50-55ºC), but by turning them to 7V I have slightly more noise, but 2ºC less on GPU and 7ºC less on CPU.
Reactions: 2
yes it can my w/c loop can be on silent mode 33-38 C idle
just turn down the fans to low. plenty quiet if they are properly located
qft
i ran my yate loon high speeds (11 of them) on low all the time on my i7 @ 4ghz, i never even bothered turning them up
Yeah its always better to over-do the rad size just for this purpose. Crank all your fans down and enjoy the silence.
Reactions: 2
If I even had a WC loop, it wouldn't really matter for me, my PC never needs to be quiet because I use headphones for everything.
I'd probably see if I can achieve sub-ambient noise levels, but I'd never use it outside of benchmarking.
But when you sleep near your PC and you have it turned on...
I run u triple rad with 3 800rpm fans and it keep my temps under 50 while gaming and that is with my sig rig. It is almost As quite as a Dell and so much more powerful. Next I'm geting a xspc rad with typhoons and see how that works out.
I run my sig rig almost 24/7 and it is quiet as can be. I hear nothing from the pump or flowing of water at all, the most I hear is a quiet airflow but drowned out by the sound of the A/C most of the time. Sometimes I hear the HD working but that is about to change when my SSD comes on Wednesday
right now, im at 4.0ghz, and i have ONE(1) fan on my rad at 1080 RPM every other fan is completely off, except gpu of course, its at 25%. i run like this all day long until i play a game.
temps right now....
Granted I'm only on a C2D, but my raptors are louder than anything else in my computer room. The joys of a triple rad with a c2d is that I never turn my fans above the minimum (5v?) on the fan controller even when gaming. The only time my system makes more than a slight noise is when the GPU spins up after a period of time in games.
temps right now....
mmmm, love low temps @ high clocks xD
Right now the only noise my system makes is from the pump (a dull hum, MCP655 variable on high) and a waterfall sound from the bong.
When I get my naja cooler completed it'll make 0 sound, save for the pump. I may even turn that down so its dead silent. I expect idle core temps around 30-32.
Thanks to all for input on how their rigs respond too being used in silent mode. Since I think this info is benifical to all i give +rep to all.
My cooling system is always in quiet mode
. The only thing I hear is my GPU fan when it is under load. Aside from that, full load temps on my processor are around 36 with one Yate Loon low speed @ 9v.
1 - 20 of 28 Posts
