1 - 7 of 7 Posts
Today I restarted steam and it now doesn't start up anymore. Downloaded steaminstall straight from steampowered.com, installed, still doesn't work. What can I do now, it works just yesterday.
My steam takes like 5 minuites to come up. i have no idea why it does this, it just takes a very long time from when i click the icon, to come up.
Open the task manager and make sure all process's of steam.exe are not running.
Navigate to your steam folder(eg. C:\\Valve\\Steam) and look for the ClientRegistry.blob temp file and delete it, then run steam again
This should help and ask for your login infomation again.
I have this problem all the time and this always fixes it
Hope this helps
Mad
Originally Posted by DaRkLoRd65535
u mean c:\\program files\\valve\\steam
sometimes c:\\program files\\steam
What he said
My Steam is on a seperate partition so I dont lose all my mods + skins when I format XP
Discussion Starter #7
Uhhhh, I copied the steam.exe over from the new dir and it works...thanks lots guys.
1 - 7 of 7 Posts
