1 - 5 of 5 Posts
Watercooler
Woke up in the middle of the night so decided to check my folding program.
2080ti was running very slow, almost 2 minute TPF so pulled the work unit.
To note, i have reinstalled my GPU driver and folding at home including deleting data file many times.
When i add a GPU slot, it instantly deletes itself.... every time.
I don't know what's going on, thanks guys.
Watercooler
Discussion Starter #2
Shot myself in the foot.
I ended up doing nothing and it decided to work now.
Sorry i can't delete the thread.
Not new to Overclock.net
That's how life works, if you ask about it then the problem fixes itself.
I was installing the latest client on a new Win 10 install yesterday and had this same issue with a GTX 980. For whatever reason the client was not seeing any GPU's if I looked in the system info tab of FAHControl. I tried several times to add a GPU slot but it would just delete itself. I found that I had to install the client, reboot, start [email protected] again, and then I was able to modify the configuration to add the GPU slot and remove the default CPU slot.
Watercooler
Discussion Starter #5
This is literally what i did about 5 times then i just signed out and in after many restarts and it let me add the GPU slot.
Weird as.
You're not wrong lol :')
1 - 5 of 5 Posts
