Can't configure xbox 360 controller with NBA 2k10.
3701 Views 7 Replies 5 Participants Last post by  budgetgamer
Hi so I have a xbox 360 wired controller, and I tried setting the buttons myself but it wouldn't let me set move left down up and right all to the left stick. Are their any drivers or something to configure the buttons correctly?
UPDATE I have found the xbox 360 windows 7 64 bit drivers and device manager says they are working properly though in NBA 2k10 it's still not configured.
1 - 8 of 8 Posts
It won't work properly by default unless it's a Games for Windows Live game.
Use Pinnacle Game Profiler. That's what I use for games that aren't supported by default.
Ah thank you. I'm never heard of this can you give a short guide and link to installing it please?
Head on over to the forums and download some profiles. Your game should be in there.
http://pinnaclegameprofiler.com/forum/index.php
Ah, Im not seeing it shoot.
Try creating one yourself. It's very simple and it shouldn't be too difficult to get to working properly.
PC Gamer, you will love Pinnacle Game Profiler, otherwise you can give a try Xpadder .
Hmmm, I play the same game with a 360 controller and had no need to configure the controller. The default setup was perfect for me and played virtually the same as if I was on a console...
1 - 8 of 8 Posts
