Can't decide between E5200 or Athlon II 240, owners please post underclocking results
820 Views 9 Replies 8 Participants Last post by  rasa123
I am going to get an updgrade for my linux machine. It uses a opteron 165 in it, which is way to hot. I am thinking about either an E5200 or an athlon II dual core for a replacement. The perform about the same, I want to underclock them in my system either at stock speeds or down to about 2.0ghz. Ideally I want the one with the lowest power consumption.
If any owners of an E5200 or an Athlon II dual core could post their voltages and speeds underclocking their processor I would really appreciate it, and would help me make a better decision. I am interested in particular with results of:
E5200 (or similar processor) at 2.5ghz and 2.0ghz
Athlon II 240 (or similar) at 2.0, 2.5, and stock speeds.
Thanks in advanced
1 - 10 of 10 Posts
well why not get what i have if you want a cheap cpu that uses low voltage? my e3200 uses like around 1.15v for 2.4Ghz stock, i would imagine that for 2.0Ghz it could use close to 1.0v. This chip also has VT unlike the e5200, so if you wanna use perhaps vmware or xp in windows 7 then that comes in handy
Thanks for that information. I didn't know that intel offered VT support for anything but thier core2duo? I will be considering this processor as well thank you.
you could also try getting one of the low power 'e' CPU's...
my bet would be AMD though
It has been my experience that the lower clocked processors can be emulated and better with a higher clocked version underclocked. To get down to 45 watts with an Athlon II 250 I would just have to reduce voltage and/or clock speed by 30%. Something that can probably nearly be done at 3.0ghz.
I've seen someone take a tri-core phenomII down to 90mhz and something like .5v so I would say the AMD chip would win out.
You could get an AMD Athlon II Χ2 235e:
http://a-power.com/product-13718-0-1
AMD Athlon II X2 235e:
2.7 GHz
45nm SOI
2MB L2
socket AM3/AM2+
45W
0.85V - 1.425V
Intel Pentium E5200:
2.5 GHz
45nm HMGK
2MB L2
socket 775
65W
0.85V - 1.3625V
Think the Athlon wins here...
Originally Posted by webguru1985
Intel C2D
Useless post.
My E5200 can reach 3.75GHz stable with 1.35v Vcore, tempt never breaks 55 degree Celsius. I'm setting at 4.0GHz with 1.425v because I plan to change it soon.
I definitely recommend you the E5200.
I would go with the Athlon. Lower voltages and you wouldn't be using a "dead" socket, so you could upgrade later if you used an am3 board. Just my two cents.
1 - 10 of 10 Posts
