1 - 9 of 9 Posts
when i try and defrag i get a list of files that cant be defragged and it stops<br><br>
they are files to do with BF2, what can i do about it?
are you playing bf2 while defragging? Defragging should be done when the comp dosent have any files opening.
Discussion Starter #4
nothing running while defragging.
Then i'd follow jacks directions, boot in safemode then defrag.
Discussion Starter #7
so do you never defrag?
What are you using to defrag? I hope its not the Windows one that comes with it. Download Diskeeper and see if it helps.
Discussion Starter #9
yes i was using the windows 1 and i'll download diskkeeper
1 - 9 of 9 Posts
