As the title says, I just can't get even 100 hz boost on my FX-6300 - it won't boot even if I change the voltage to a higher value. Tried reseting the bios by removing the jumper, it didn't work. Then I removed the CMOS battery and the bios didn't reset at all (no clue why). What's wrong?
My MB is ASRock 980DE3/U3S3 , I got an aftermarket cooler -> 30 celsius degrees in 100% load, that's why I want to OC the hell out of it and that's why I bought the aftermarket cooler, but somehow I can't even get 3.6 GHz.. what's wrong guys? Btw, after I change the settings in bios and the pc shuts down and then starts again (which is normal from what I heard), I get this message: "The system failed to boot several times before. You may press f2 or DEL to enter setup to reconfigure your system. Or BIOS will continue to boot after _ seconds."
Thanks a lot!
Thanks a lot!
