Can't figure out how to remove atx pins
629 Views 5 Replies 4 Participants Last post by  radodrill
Someone please explain to me what I'm doing wrong :shrug:
I'm using this double sided tool from frozen cpu.
http://www.frozencpu.com/products/38..._Fan_Flop.html
So I'm doing exactly what they show on the murdermodz site to the atx in order to remove the pins. Unfortunately it's not working at all. I tried this on a psu, extension, and other cables. I used both the double and single side. I can't figure out what I'm doing wrong :shrug: :shakes:
1 - 6 of 6 Posts
Take a picture of the plug (the pin holes)? Some plugs are actually made in a way that makes it nearly impossible to remove. In some cases, you have to cut the plug apart.
Seriously? I didn't know that
Okay, I'll take a picture now. Thaks for responding so quickly ducky. I thought all of the pins were the same, but now I know.
Update. I got one out
There are two tabs on the outside of the pin that have to be pushed in.
The 2 prong tool needs to be jammed on the outside of the pin, not inside.. Then pull hard on the wire.. should come out.
case closed.. thanks everyone!
yeah the fingers are on the outsides of the pins
I've pulled 56 ATX pins to sleeve my PSU
1 - 6 of 6 Posts
