Can't find any DDR3 for my 790i, help?
317 Views 5 Replies 4 Participants Last post by  Stewart=B
I can find any ram that support my motherboard and i really want to upgrade to 4 gbs
i live in UK and all ram sets on internet are for Core i7s etc
1 - 6 of 6 Posts
Originally Posted by Buggedout
What make and model is your mobo?
Erm, hmmm
does that matter, but i think it is one of the earlier ones.
where should i look for info if i have to?
any dual channel ddr3 should work. if your mobo requires 1333mhz ram and you can only find ddr3 ram that is clocked hight, the ram speed will scale down to the automatic rated speed, it also gives you alot more headroom for overclocking the ram
Originally Posted by Stewart=B View Post
Erm, hmmm
He means what brand is it. The above comment has it right.
EVGA. not sure about model number though
1 - 6 of 6 Posts
