1 - 20 of 33 Posts
Initializing...
Originally Posted by youra6
Is there an option on your BIOS to turn on SLI?
Yes there should be!
Check to see if both cards a running SLI in BIOS 2 x PCI-E 16x of coarse.
If that don't work you might have to clean with Driver Cleaner Or Driver Sweeper in safemode and reinstall your Nvidia Drivers.
Try the following: I think this will do it if you already have done these:
-checked thru BIOS
-uninstall driver thru Drivesweeper thru safemod
-reinstalled new driver afterwards
-Tried to rollback older drivers
-Tried using Nhancer
Try switching to a different PCI-E slot.. Should work
I think your mobo is faulty
On my Bios there isnt. Theres only an option for hybrid SLI, choosing PCI-E or PCI to come first and some other options nonrelated to turing on SLI
Mine just doesnt have the option, different mobos have different setups
/╲/( ͡° ͡° ͜ʖ ͡° ͡°)/\╱\
I suppose you might as well enable the hybrid sli.
Could try EVGA Precision to sync the gpu's. But thats more working around the problem then fixing it
Discussion Starter · #17 ·
ok i cleansweeped the drivers and installed them again - didnt work
switched the pic-e slot - didnt work
i had my gtx 260 in the same pci-e slot and it worked, so i dont think its my pci-e slots its gota be software related and i also looked a few times in bios but couldnt find anything to do will sli other than hybrid sli.
now what?
With the 295 installed a driver reinstall should pick it up.
1 - 20 of 33 Posts
