1 - 16 of 16 Posts
Try lowering your cpu llc to Ultra High and cpu/nb to Regular. Also cpu/nb current capability to 100%. If that works then you may even be able to lower your cpu voltage for 4.4ghz from 1.45v a few notches. Or at that point bump up to 22.5 (4.5ghz) and add cpu voltage if needed. Be sure to keep an eye on temps.
Reactions: Miubhi
Ok will do. Just came upon a huge discovery with my haf -x case. i opened the back of the case and blew some can O air on the back of the cpu area and watched the temp drop 15 deg C. so with a small fan blowing on the back of the mobo the temp dropped to 49c and 43c on cpu0-7 so going to mod the back of the case with a filtered fan coming in to lower that heat build up. then i can get back to the adjustment. cant wait
Discussion Starter · #8 ·
i have Danger Den Monsoon Premium D5 Bay Reservoir with pump, black ice triple rad on inside top with push pull, a single black ice rad in back push/pull set up the full looped system only running cpu and xfire 6970 xfx cards both gpu are oc'ed 950/1450 with volt push had them at 1000/1500 and temps were max 80c under furmark for an hourbut i returned the gpu to 950/1450 stock volts. just cant seem to get the cpu temps to stay down. now after i pull the back cover off the Haf X casethe cpu temp drop quick like a dropped in a bucket of ice. so im considering putting a fan on the case to keep the temp reduced ... bad idea or good?
What is your VRM or NB temp? You might try a fan directed there.
System looks great btw.
I had the same problem until I read this! I also have fx 8350 at 4.2ghz but when i run prime95 the CPU temp goes up to 60c+ fast and core temp gets up to 51c max. when idling, its fine....I will give this a try first thing in the morning mate, and edit with an update.
Discussion Starter · #14 ·
Thanks.. yeah the volts were alittle whackey at first now everything seems to be under "better" control i do have to run 1.450v to keep stable at 4.5g clock speed thou. tried lowering in increments of .025 and even at 1.425v it error-ed in OCCT after 25 minutes.
1 - 16 of 16 Posts
