1 - 7 of 7 Posts
So a while ago I was asking for recommendations on a monitor (see the topic if you want).
I got the LG monitor a week or so ago. I also got an HDMI cable from monoprice.com to go with it since I didn't want to connect it via analog.
Thing is I can't get the colors right via HDMI. I thought I had it set until I saw something with red text, particularly red text on black background. Extremely blurry. I did a bit of research and read that pure red is hard to deal with for some kind of technical reason. Thing is I don't really care about whatever the reason is, because my old monitor, which was hooked up through DVI, looked great.
It looks OK through VGA but I'd much rather not be using an analog connection.
I'm assuming it's behaving that way through HDMI because my video card thinks it's hooked up to a TV and is "optimizing" the settings for a TV. I guess the monitor I got is a TV rather than a computer monitor but I'm using it as a computer monitor, soo... might anybody have an idea as to what I can do? I've used Calibrize, it didn't really help.
At this point I was considering getting a DVI to HDMI adapter so I can use a DVI port on my video card, and maybe that would help?
control panel > display > screen resolution >advanced settings > monitor > change colours to high colour.
if that fixes the blur then its because of temporal dithering of the display due to it only being a 6bit panel and not an 8bit panel.
if it doesn't then try changing overscan settings in the CCC
For anybody stumbling across this thread in the future, I fixed it easily by getting a DVI to HDMI cable on eBay such as this one. Got it yesterday, installed it today, plugging it to one of my GPU's DVI outputs, put the other end in my monitor's HDMI input, and everything looks awesome without any tweaking.
I'm guessing there's something about the GPU's HDMI port that makes the drives put out a modified signal more adapted to actual televisions, but there's nothing I could really do to either the monitor or the drivers to correct it.
i got a cheap monitor too that has a blueish picture. but i got used to it now and dont see it. lol.
it came with that same dvi hdmi connector. but i must use hdmi hdmi. i've never used the dvi hdmi connector maybe i'd solve the blueish tint. but i dont see it anymore... i noticed it day one only.
1 - 7 of 7 Posts
