1) Make sure you have a clean driver installation. If you have an old driver you use 3rd party driver cleaner to remove it. The install the latest available driver from ATI.
2) For video to work adjustments are done through the CATALYST CONTROL CENTER(ccc). You can righ click your mouse to activate it.
3) Options on CCC
3.1- Desktop & Display: Provides you the information on your display.
3.2- Desktop Properties: PROPERTIES provide the settings on your display.
Find the settings that will match the capability of your display
3.3 DISPLAY OPTIONS: It defines the detection method of the video card use for the monitor.
hope this helps. look thru every menu/submenu/tab/subtab in CCC and look for "overscan" youll wanna move the slider to 100% for some reason it defaults at ~80% thru hdmi.
are you sure you downloaded the correct catalyst driver? i mean.. the correct version?
Try downloading the latest one, if that doesnt work, then find the second newest one and try that!
Overclock.net
