1 - 16 of 16 Posts
hello guys, i have bought a new hdmi cable to connect my computer with the lg lcd tv i have here, the tv supports hdmi cause the ports are on the back of the tv..
i hooked everything up, so i enabled 1920x1080 and have a very ugly screen..
i whas trying to screw with my tv settings, but it leaded to nothing...
i have a HD5570 1gb gddr5
Discussion Starter #4
its just so strange, when i choose another resolution then 1360x768 then its so uggglyyyy
when i choose 1080p in ati catalyst its super-ugly (no-hd)
the screen is overbright, and blurry, and ugly...
EDIT: my lcd should support hd resolutions cause of the hdmi ports on the back, right?
Maybe your lcd is for 1360x768?
My tv is 32", however, it's supports 1080p but with ugly screen in desktop, and good in games, dunno why.
Try to find an overscan option in the TV.It should be off.
It's sometimes called "just scan"
HDMI is the worst cable IMO. I have to use it for my main screen, And it's not very good.
Also try changing HDMI cables.
@PureDorian. I know... This is prolly the reason. And you should get a nicer image with your native res + 4xAA. It should look better than what you just said.
Hi, Im assuming it doesnt do 1080P. Just because a TV has a HDMI port doesnt mean it does 1080P. 720P is also considered HD.
Your TV does 1360X768 max?
Discussion Starter #9
1360x768 is the clearest resolution i can get, anything over it makes it look ugly
also tried 720p, ugly to..
Originally Posted by De-Zant View Post
As I said, HDMI doesn't work with unnative resolutions. Continue to run it at 1360x768 or it's gonna be painful.
Which is "unofficially" called 768P (1366x768), also HD. but this is typically a plasma resolution. What TV/monitor do you have?
NVM... saw it in your sig.
Discussion Starter #15
but it also says this
Just Scan HDMI/Component: 1080i / 1080p / 720p ???
and it doesnt work if i choose 1080p, it becomes uggglyyy
Hi, not sure if you tried this, but can you turn the "Just Scan" feature off?
Doubt it will work, or even if you could, but try it.
1 - 16 of 16 Posts
