1 - 3 of 3 Posts
For the life of me I CANT GET INTO BIOS!!!!
I have a Toshiba Satellite C55-A5243NR
I have tried all of the methods mentioned on the Toshiba website, I have tried this also without the battery and by unplugging the power source to make sure it shut down.
All the happens is it goes back into windows 7 or it goes into Windows Boot Manager to load Windows 7
http://forums.toshiba.com/t5/Windows-7-Knowledge-Base/How-To-Enter-the-system-BIOS-on-Windows-7-computers/ta-p/275629
F2 key method
Turn the computer on.
If you see an invitation to press the F2 key to enter Setup, do so.
The Setup screen will appear.
If this method does not work, repeat it, but hold F2.
F12 key method
If you see an invitation to press the F12 key, do so.
Boot options will appear along with the ability to enter Setup.
Using the arrow key, scroll down and select .
Press Enter.
If this method doesn't work, repeat it, but hold F12.
Esc key method
Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
1 - 3 of 3 Posts
