Can't get into BIOS
1450 7
On POST while clicking F1 (holding down) I only go to the Windows Boot Manager and no BIOS setup screen.
1 - 8 of 8 Posts
on my pc, the key to get into the BIOS is the delete key or F2, I think, so check the other F keys and you should enter it
i think i have played with his sig board, it should be DELETE key.
It will either be, Del f8 f11 f12
I don't think it is his sig rig because he said he'd be back after checking the F keys yet his status says he is online
Dont forget takes 15 mins before it registers he logged off unless he clicked log out
1 - 8 of 8 Posts
