Hey guys.. Just got my mushkin redline in. Its rated for 2000mhz at 8 8 7 24. I had some problems running at 2000 so I ran at 1600 7 7 7 24 74 fine... Perfectly.
I posted on the muskin forums and was told to run at the rated speeds with voltages for: "VTT- Between 1.4 and 1.55v, some systems can take up to 1.65v" and "DIMM Voltage - 1.60v - 1.65v"
Now I've done each and every combination possible for the two voltages, going through one of the 3 dimm voltage choices and trying every vtt.... Each try either auto restarts me within 20 seconds of starting LinX or it locks me up until I hard reset... 1600mhz 7 7 7 20 passes fine though.
I've already set back down to default settings (everything except the ram related settings) .. any ideas what I could set to get this working?
