Build:
Intel 3930K
Rampage 4
32 gigs of G-Skill G.SKILL Ripjaws Z Series (8 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Mod
SSD 120gigs
ENERMAX SGALAXY EVO EGX1250EWT 1250W
EVGA 580
ASUS Xonar Essence Soundcard
Windows 7 Ultimate
Don't know if I need to list anything else for this issue.
Anyhow, I went from a Rampage 3, I7 930, and 12 gigs of ram to what is listed above. I switched because my external water cooling unit went out. Once that happened, I opted to upgrade my rig instead of replacing my external water cooling unit. Got the system built, and it boots to bios no problems. However, installing windows has been a pain....
When I first tried to install windows, I got the following error message: The selected disk has an MBR partition table. On EFI systems, Windows can only be installed to GPT disks.
I checked the internet to see what I had to do to fix the problem, and I found out it was how my DVD rom was trying to boot the Windows CD. In the Rampage 4 Bios there is an option for the DVD rom under the "Boot" section that allows you to change the DVD type to either UEFI, or not UEFI. Anyhow, I changed that to not UEFI and booted into the windows installing menu. Windows went through with the installation, but now it still wont boot into windows. After the windows logo, my screen goes blue and my computer restarts. If anyone knows what to do about this, I would really appreciate it. I don't know if I need a new program or not. I read about the GPT and MBR stuff, but didn't really understand it to well. Additionally, I don't know if this is being caused by a hardware issue or just from faulty files on the hard drive due to other problems I was having before. I'm kind of leaning it's a faulty install for some reason, but I don't know how to get around it. The windows is also a legit copy as well. I've reformated and reinstalled several times with the same windows program on my previous rig and never encountered this issue.
I'd also like to add I don't know how to get windows boot manager to show up under the "Boot" menu in the BIOS. I don't know if that will help or not seeing that I've seen a lot of posts on that
Intel 3930K
Rampage 4
SSD 120gigs
EVGA 580
Windows 7 Ultimate
