1 - 4 of 4 Posts
Why cant i go higher on my P4 2.6 GHZ 800FSB, i get to 3.1GHZ and it doesnt start, the fans start working but no video, so i reset the bios. It works but why cant i go over 3.1GHZ, i tried raising the voltage from 1.525 to 1.6. im using an Abit IC7-G motherboard.
it may be that your ram is maxxed out, see what speed its running at, and what its rated at. also try raising the momory voltage, that should help
1 - 4 of 4 Posts
