1 - 11 of 11 Posts
Title says all; I tried to overclock my Sapphire AMD R7 265 memory clock but it can't even handle 5mhz jump to 1405mhz before I crash (stock is 1405). Temps are in check and I have the latest stable Cataylst driver. My core clock is overclocked though to 1080mhz. Please help!
Thanks.
Fan Man
Thanks.
No, stock is 1400.
What's missing in your post is a detailed description how (in which manner) you're attempting the overclock.
Originally Posted by CurvedLine View Post
No, stock is 1400.
Whoops, your right.
I am using the latest version of Sapphire's own TriXX to overclock.
Here is a screenshot of my current stable overclock: http://prntscr.com/5u0d1y
i've had good luck with Sapphire cards. I have 2x of their 7970's. hope you are having luck with Afterburner, that's what I use too. make sure not to enable the OverDrive in the catalyst control center.
Put your Power Limit % maxed at +20
Discussion Starter · #8 ·
To get past the AMD BIOS limits, do I check "Extend Official Overclocking limits" and "Unofficial Overclocking mode with power-play support?"
I wouldn't mess with the unofficial modes before you are sure you are actually getting results with the "in range" settings...you could screw up your card.
do you have the latest version 4.1.0 i think?
now mind you, I have a completely different card..but heres my settings for AB itself
edit: I have 4.0.0 installed, havent updated to 4.1.0 yet
Well, I had formerly OC'd my card with Sapphire TriXX and was stable @ 1075mhz. Should I go for a spin with the "Extend official overclocking limits"?
EDIT: My stable is when I can play my games without artifacts or AMD display driver crashing. fair enough?
1 - 11 of 11 Posts
