The only GPU I currently have is a XFX GT640 4GB and it runs very cool as it only draws something like 60 watts. I would like to overvolt it by flashing an edited VBIOS.
I used keppler bios tweaker v1.25 (other versions don't work) to edit the bios. There are only 2 power states on the card. I can successfully change the lower power state voltage and everything works fine but I cannot change the higher power state voltage at all, if I do the card is not detected even after reinstalling drivers and I only get output on one display.
So currently I have the card running at 1.112v on idle at 324MHZ and running at 1.1v under load at 1045MHZ.
Is there any way I could successfully edit this VBIOS?
