1 - 8 of 8 Posts
Stock Speed--500MHz 3d core, 300MHz 2d core, 1GHz RAM
Current Speed--550MHz 3d core, 325MHz 2d core, 1.07GHz RAM
Temps--Idle 44, Load 65
All stock cooling, AS5 on the GPU. I should be able to push my RAM further, though, right? Any ideas?
I would check if the ram is getting really warm-hot. If it is then ramsinks should help a bit. But yes, you should be able to overclock your ram father as usually 1150 is even easy for 6600GT's and many run over 1200.
1 - 8 of 8 Posts
