I've tried the "Force PCIe Gen3" patch on my MSI BBII + 3930K but it caused a 'no signal' msg on the monitor.
Thinking my OC had something to do with it, I switched to the 2nd Bios at stock settings and set the PCIe speed to Gen3 in Bios and reset, only to be greeted with the same 'no signal' msg.
Thankfully, MSI has 3 Bios's so I'm currently on Bios C. However, to reset Bios A and B, I have to use a jumper according to the manual:
Which I don't have. So I tried with a metal tip screw-driver shorting the 2 pins but no change.
Any advice ?
Any advice ?
