1 - 4 of 4 Posts
Go to options then click run benchmark, I have the same problem. I think its because we are running HDTVs and the res is 1360x768.
yeah tried that but doesn't work.. actually turning off the featured tests made it work but get another error.. check it out....
BTW furturemark FAQs
Q: I get an error when I start 3DMark Vantage 1.0.0 which says "Error occured in DLL. Error type: std::exception Error message: boost::filesystem::create_directory". Is something wrong with my system?
A: This is a known issue in 3DMark Vantage 1.0.0. The error only appears randomly on the first run of 3DMark Vantage. You can ignore the error as it doesn't affect your benchmark results.
Update: Please download the new hotfix 1.0.1 for 3DMark Vantage as it should correct this issue.
ALREADY GOT THE HOTFIX!!!
1 - 4 of 4 Posts
