this^ put load on the CPU and watch CPU-Z,
Yep tried speedstep. Same thing. Ai suite that came with my motherboard. it gives me an error when windows starts.Originally Posted by deafboy
Anything happening after you save the settings in the BIOS? Like trying to boot a couple times?
Anyways, disable speedstep for the time being so it's just running at the overclocked speeds the whole time and not going back down...
as for the GPU volts...what are you checking the volts with?
I disable it and it just runs at 3.4 all the time. regardless of what the multiplier is in bios. It does show the voltage correct though which is odd.
Well this is weird....When I use OCCT, it shows the overclock correctly. When I use real temp, it resets to 3.4! Weird, isnt it???? Will try reinstalling real temp... Who knows.Originally Posted by thomasgiles2012
try using this program called occt.(http://www.ocbase.com) i have to use it sometimes on intel cpu's.
Yea. If you turn of turbo in bios your overclock will not record. No idea why. So keep turbo on in bios and let her rip.
